Solved
Help me pick an mATX case!
  • Power Supplies
  • Cases
  • Build
  • Motherboards
  • Components
  • Product
Last response: in Components
a c 107 ) Power supply
a c 176 V Motherboard
October 1, 2012 6:01:30 PM
I currently have a decent build centered around an mATX motherboard. It is all inside a normal case and I want to do something different and more interesting. Help me find a cube or some other interesting case that is cheap and small. (Do not want an mATX tower. Hence something "interesting") Interested in lan boxes and what not also. Just want to keep it VERY cheap.
My build has a normal power supply (antec 450w), normal CPU heat sink, and an HD7770.
Also has one 3.5 HDD, one DVD drive, and a fan controller that doesn't need to be included if space is an object.
Thanks! All case ides welcome!
More about : pick matx case
Best solution
a b ) Power supply
a c 75 V Motherboard
October 2, 2012 2:18:36 PM
October 2, 2012 2:22:03 PM
TheBigTroll said:
great case on the cheap
http://www.amazon.com/dp/B0074V2UXI/?tag=pcpapi-20
I have just bought that case, it bloody small but all fits in ok!
If you want a cube check out the SUGO series.. think 02 was cheap ish...
m
l
October 11, 2012 12:40:43 AM
Best answer selected by tiny voices.
m
l
October 11, 2012 7:48:34 AM
Hi mate just to let you know i purchased the official fractal design side and rear fans form the 'box' ebay store, worked out about £12.bargain!
m
l
October 11, 2012 10:17:48 AM
Quote:
the fractal core 1000 gets hot,i read a bunch of reviews on it. it depends on what you have in the case though....
Fans barely whirl up with the junk inside my case and that's before i bought the above mentioned fans. Great tiny case with noted airflow characteristics.
Have you got the link to the reivews, id like to make sure im not making the same mistakes as the reviews. :o
m
l
Anonymous
a b ) Power supply
a b V Motherboard
October 11, 2012 12:45:55 PM
http://www.anandtech.com/show/5736/fractal-design-core-...
yeah it really does depend on what you put in it ... if i remember correctly, they tested the temps with stuff designed to get hot
other than that...i think this is pretty good case for its price.
m
l
October 11, 2012 12:55:59 PM
Ah yeah I read that review, they seem to contradict themselves a bit in the conclusion and did you see their build..cables everywhere!! :)
There's no doubt the case you recommended is far better but for the £26 I paid I think it works perfect. Best budget case I have ever come across
m
l
March 17, 2013 6:31:56 PM
The A30 has horrible airflow and cooling...
m
l
