Will a 500w Corsair power this?
dg1598
56
i5 2500k
AMD 7770
8GB DDR3
More importantly does it have enough cables to power the fans on a zalman z11 case?:)
dg1598
56
Sorry, major noob haha, what are bridge cables?:) also the zalman case comes with 5 fans! some molex some 3 pin!:) will it be sufficient? i would look myself but i dont know what im looking for! haha
your rig is very unbalanced. id rather get a i3 3220 and a 7870 instead of a i5 2500k and a 7770. way more gaming performance
as for the power supply, heres what i would get. corsair cx power supplies are pretty low quality if you ask me
http://us.ncix.com/products/?sku=59615&promoid=1210
bridge cables im pretty sure he meant was extensions. you probably wont need them
the xfx has molex plugs and the rest of the 3pins can go to the motherboard. if you cant fit them, there are always molex to 3 pin adaptors.
