Help/advise with pc build
Last response: in Systems
June 4, 2012 8:36:20 PM
hey there :D
im new here and i need help with my pc build im soon to buy, i wanna be able to have the option to play games on high with a good framerate and from the price ive seen its cheaper to buy parts/components to put together yourself rather than buy a already built pc.
the games i'd most likely look to play would be guild wars 2,
would you advise:
Intel i5 2500k CPU | MOTHERBOARD BUNDLE | 8GB MEMORY (already assembled cause im newb :D ) (nice OC)
http://www.ebay.co.uk/itm/Intel-i5-2500k-CPU-MOTHERBOAR...
gtx 570 (maybe bid on one to save cash)
http://www.ebay.co.uk/itm/PNY-NVIDIA-GeForce-GTX-570-PC...
i have a cooler master gx 750w but the wires seem abit much for my pc case.
reason for new build is my pc aint really up to scratch (BIOSTAR n68s3) the cpu max's at phenom ii x4 955 which would bottleneck the gtx 570? xD
is there anything ive missed that i need to know?
i know this is abit newbie and stuff but help is appreciated thanks,
- EDGE
More about : advise build
June 4, 2012 10:02:33 PM
Not that bundle
The mb has a p67 chipset. Its the first chip set that could run sandy bridge processors and has been improved a lot with added features on Z 68 and Z 77 boards
The mb is m-ATX which might or might noit be an issue
The cpu cooler is not a good unit
and the RAM is probably rated foe 1.65 volt operation . Anything above 1.5 volt voids your processor warranty
The gtx 570 is a good card but there is sometimes better vale in the newer 7XXX series radeons
June 4, 2012 10:16:53 PM
Outlander_04 said:
Not that bundle
thanks alot for the reply and the suggestion with the gpu
any idea of what i should get towards the mb bundle? :)
June 4, 2012 10:26:12 PM
i5 2500k or i5 3750k
mb with a z68 or z77 chipset
2 x2 , or 2 x4 gig of 1600 Mhz RAM rated for 1.5 volt
RADEON 7870
500 watt psu
40 gig cache SSD [ if its in your budget ]
1 terabyte hard drive
decent gamer case . HAF 912 advanced , Antec 300 two , Corsair 400
And read this forum for a few days . Look at solutions others with your budget have come up with
June 8, 2012 4:57:20 PM
thanks for all the replys im just wondering if i had a phenom ii x4 955 would it bottle neck a 7850 or 7870?
also which case is wise for gx750w coolermaster (wires and wires :/ )
thanks EDGE
