Gtx 260 power supply
Hello, im rajitha and im new for ur forum
i need to know how to supplt external powe for gtx 260
i have foxconn g 32 and 400 watt mercury normal power suppl is it enough?
3 answers Last reply
More about power supply
  1. You mean Foxconn G31 right? there is no G32.
    http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-260/specifications
    According to Nvidia, a PSU that has max output of 500W and has 2 6-pin (or 8&6+2), PCI-E connector or over will run GTX 260
    I don't think you can run it, otherwise you need to upgrade your PSU, this is a great one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035
    Or change the card to cards that require lower power requirements
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161403
  2. thanks
    yes i have g31
    why i cant run using my power supply?
    if i connect using my power supply what will happend?
  3. Maximum Graphics Card Power (W) is 182w for this card
    so if i use my 400watt psu i think it may enough
    am i right?
    wt can i do without buying new psu to this card?(im not rich :( so i need a cheap solution )
    and another question i has saw 3 display gaming can i do that using this card with a splitter
    http://www.ebay.com/itm/DVI-I-24-5-Male-Dual-VGA-Y-Splitter-Female-Adapter-Splitter-Cable-1-2-/320876715971?pt=LH_DefaultDomain_0&hash=item4ab5be1fc3#ht_2787wt_1139
Graphics Cards Gtx Power Supplies Graphics Product
