I have a new build going on here and am having a problem. I'll try to explain with good detail, i hope.
Components:
Intel i5 core ivy bridge 3570k
ASUS P8 H77-V motherboard 1155
16GB (4x4gb) Corsair Vengence 1600mhz DDR3 240pin RAM
Crucial SSD 256GB
(2) Liteon ihas 124
Antec 300 case
CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
Evga Geforce GTX 430 Fermi
Problem:
When i power on i don't get a picture on the monitor, no post into bios, no beep, the fan on the graphics card doesn't spin, the power supply spins, , the disk drives open, the case fans run, and the computer won't manually (holding down the on button) shut down; i have to shut down by turning off the power supply.
What I've done:
(1) Disconnected all devices (hard drive, optical drives, front panel connectors, etc)
(2) reseated everything (RAM, CPU, MB, SSD, Disk Drives, VC, etc)
(3) Reset CMOS
(4) Tried 1 stick of ram in the correct dimm slot
(5) Tried using the onboard monitor connection without VC installed
(6) Tried a different monitor
(7) Tried using DVI and VGA connections
All the options i've tried resulted in the same problems listed above. The weirdest problem imo is that i can't power down manually from the front panel. Any suggestions? Is it a simple error that i could be overlooking or a DOA of one of the components, etc? I know it's hard to offer a diagnosis over the web, but maybe a fresh perspective could help.
Thanks for any help or advice that's given in advanced!
Components:
Crucial SSD 256GB
(2) Liteon ihas 124
Antec 300 case
Problem:
What I've done:
(3) Reset CMOS
