Hello all,
I'm just wondering if my temps are normal with my H80 that was just installed. I'm running an intel i5 2300 currently at 3.0Ghz and getting idle temps at 30c and load temps at 49c with a room temp of 75 fahrenheit. The H80 is set to increase under load and has normal stock fans. Should I run the H80 at max always? I'm sure the temps will decrease once winter comes around but wondering if these temps are normal. Also, I didn't install the H80 and am wondering if I can increase the speed via the block button without any problems.
Thanks guys
Thanks guys
