New system build, what do you think?
What do you think? Im not 100% on the mobo/ram yet. Its been difficult to try and find the best combo. So many different Asus variants out, just finally clicked it. I dont really like everything being enclosed, incase a fan fails. Video card should last a while. Still need to make sure the cooler and video card will fit in the case;
Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case, come with Five Fans, window side panel, top HDD dock
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
EVGA 02G-P4-2670-KR GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified.
Arctic Silver 5 Thermal Compound - OEM
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9Q-16GBXL
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-3820 Sandy Bridge-E 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W Quad-Core Desktop Processor BX80619i73820
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler.
LG Black Blu-ray Burner SATA WH14NS40 - OEM
2 answers Last reply
More about system build think
  1. Seems a very balanced build, 16 gigs seems a little overkill to me but hey, I use the 1155 socket so im kinda of mainstream, remember that the blue ray its oem, so i dosent come with a program to play blue-rays, you will have to pay for one later, i raged alot when i noticed that and it was too late, there was another one that came with the program for 8 usd more lol.
  2. looks solid to me but i would only get 8gb of ram and if your not plan on getting two 670 then you don't need 750watt PSU you could just get this http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095#top
New Build Systems Product
