Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.customize (More info?)
I have a this working WXP machine and am building a new one.
My XP is WXP Pro and is legal and activated.
My intention was to install the same WXP on the new machine, knowing
that I would have to activate it within 30 days and discontinue using
it on the first machine.
The install went fine, and now I want to network the two machines
together, in order to transfer much data from the old machine to the
new one, before the 30 days is up.
My problem is that I can't get either machine to recognize the other
or any of its files. So I am stuck.
I have File Sharing active on both. The machine names are
(conveniently) machine-1 and machine-2, and are in the same workgroup
(home). They are linked via a D-Link router.
Since I have networked before, I thought I knew what I was doing. Now
I wonder if just maybe WXP will not allow networking because the SAME
copy of WXP is installed on the two machines? That is, they have the
same product key. If so, then I will have to find another way to
transfer my data.
Can anyone advise me on this? Either that I am right about the same
product key being the problem, or anything else that I might try to
get this to work?
Use AOL Instant Messenger to send your data. It is the only messanger
service that will allow you to send folders, not just files. Put all your
stuff into one folder and send it over. AIM calls folders "directories" so
that's what you want to use instead of sending a file.
Alias
Use the Reply to Sender feature of your news reader program to email me.
Utiliza Responder al Remitente para mandarme un mail.
<one@two.net> wrote in message
news:0rl9v0takosrn6tbup578tu0n2sh2llmv1@4ax.com...
| transfer my data.
| get this to work?
| Thank you
I am assuming you have broadband. If you have dial up, this may not be the
solution for you.
Alias
"Alias" <aka@maskedandanonymous.com> wrote in message
news:35k3jcF4n1nupU1@individual.net...
| Alias
|| transfer my data.
|| get this to work?
|| Thank you
That is some stoopid reply if I ever heard one.
Cross ping to make sure you can see each PC and get the low level networking
in working order, then work on permissions.
Check your permissions and users are the same on both PC's. Login as
Administrator and you'll be ok transferring files.
Just because you have the same product doesn't mean you can't transfer files
over. The hard part is to convince Bill what you're up to
> Alias
> | transfer my data.
> | get this to work?
> | Thank you
Wow! I really do not want to use AIM.
Yes - to the other responder - I DO have broadband.
I will try the ping approach to see how that works. I'll bet it will.
Thanks
>> Alias
Try Here:
Fixing Windows networking problems
> transfer my data.
> get this to work?
> Thank you
"BP" <replytoall@dufus.net> wrote in message
news:mo6dnf6nDYVEe2ncRVn-3w@conversent.net...
> Try Here:
>> transfer my data.
>> get this to work?
>> Thank you
>over. The hard part is to convince Bill what you're up to >
Hmmmm
Ping fails in both directions! I verified the IP addresses using
IPCONFIG. They remain the same.
news:m2q9v05174flaau154q76kp13jl5fbakc7@4ax.com...
networking
files
| >over. The hard part is to convince Bill what you're up to | >
| Hmmmm
| Now I wonder what is wrong?
| Thanks
Why don't you play with it for another two hours? That's one option. Use AIM
and you're done. That's the other option.
Alias
news:0pn9v0hqm945uiqru47ajljqlrnredfb7j@4ax.com...
networking
files
Why not?
Then your data will be on the other computer in no time flat.
| Thanks
I bet it won't.
Alias
OOPS!
I just double checked and found that I was using wrong IP address for
older machine, when I tried to ping it from the new machine.
When I used the correct address, the new machine can ping the old
machine fine, but not vice-versa. This implies the problem is local
to the new machine (no surprise), which BTW does access the web etc
just fine via the same router etc. Or it seems to anyway.
news:rks9v091j3176inci728talug5jvf9vll3@4ax.com...
networking
files
| OOPS!
| I scanned the web page at http://www.careyholzman.com/netfixes.htm |
| but did not see anything to help me.
| Thanks
Maybe if you fool with it for another two hours ... or use AIM and get it
done right now.
Alias
Go to "microsoft.public.windowsxp.network_web" and repost your problem along
with the output from "ipconfig /all" from both machines. A lot of
knowledgeable networking people hang out there.
> transfer my data.
> get this to work?
> Thank you
On Mon, 24 Jan 2005 05:15:20 -0800, "David Gorick"
Have you tried the wizard?
>transfer my data.
>get this to work?
>Thank you
You want the page that walks you through the NETWORK> TCP/IP (for adapter)
settings for both machines "Home Network Setup: Step by Step". If they can't
ping both ways there is a setting off in one or both. Usually an IP
address/Gateway/DNS/WINS setting.
>>networking
>>files
> OOPS!
> I scanned the web page at http://www.careyholzman.com/netfixes.htm >
> Thanks
Good chance it's the firewall on one or both machines, assuming it has SP2.
From each machine, run this command:
nbtstat -A X.X.X.X
Where x.x.x.x is the IP of the other machine. This will let you look at the
NetBIOS name table on the destination, and will let you know, among other
things, who is logged in, the computer name, and the workgroup name. You
will need the last two of the three (if you have guest or simply sharing).
If that request times out - then you have a problem. Either an IP problem
(subnet mask different accidentally?), or a connectivity problem (can you
even ping the machines from each other), or a firewall problem (XP,
BlackIce, you name it). If you have SP2 make sure the firewall is configured
to allow file and print sharing - I THINK it defaults to disallow if you
have not run the sharing wizard...
The serial number has nothing to do with it...
Venger
> transfer my data.
> get this to work?
> Thank you
