Not sure what area I should ask but here goes.
I'm needing to build a server (have WHS11) to stream videos or content to PCs & PS3s in house as well as allow access to those not in house (or when I'm away from home). I'm looking to make it simple but secure.
I'm needing a current (June 12') parts list on what I should buy. technical advice about hiccups or additional items (software or hardware) that I'll need to overcome is completely welcome too.
My preference is for a economical efficient server. One that won't kill the budget or run loud & energy hungry. I have a PC that can be salvaged for parts or mix in new stuff with a budget of say $400. I can spend any amount less than $400, but I don't think I really need to be spending over $500 for all new parts.
Around 08' I built a PC with these parts that can be used:
Intel Core2 Quad Q6600 @ 2.40GHz
Intel BOXDX48BT2 LGA 775 Intel X48 ATX Intel Motherboard
It also has a Video Card (probably ATI DDR3 512mb)
Hauppauge WinTV-HVR 1850 MC-Kit FM radio and MCE remote PCI-E x1
Upgrade to G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
1x 500GB WD Green (5400rpm?) with Vista Ultimate
2x Western Digital Caviar Green WD10EADS 1TB SATA 3.0Gb/s 3.5" Internal Hard Drive
1x Western Digital Elements 2TB Desktop External Hard Drive
Antec 400 (?) case with I believe a 450w power supply
ZEROtherm CF900 92mm CPU Cooler
Antec 761345-75024-0 120mm Blue LED Case Fan
I should have also CORSAIR XMS3 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) laying around somewhere that could be used.
The internal HDs are pretty full with mostly dvd & home movies and music. I figure to use them with with additional HDs to make the server. I also would be curious as to what form of server type I should make (raid0, 5, or whatever).
Looking for a parts list and any advice is appreciated. Thanks.
