Hello,
I recently purchased an HPE h8-1214 Desktop computer, you can look @ the specs here if needed http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03154290&lc=en&product=5192450
My question is - I recently purchased a HD Radeon 6770, I went to plug in my graphics card and everything slipped into it's slot as usual, but I came to the problem that I have no adapter from the Power supply to plug directly into the graphics card to power it.
My previous Gateway had this exact Radeon working fine, the only difference is there was a white 3 prong extension inside my CPU, that I could easily plug my adapter into, which then plugs directly into the 6-prong power slot for the Graphics card
How should I go about fixing this?
