G gonzalopino25 Honorable May 17, 2012 17 0 10,510 Jun 6, 2012 #1 is my ram working at 1333mhz 1.5v ?
Solution G Guest Jun 6, 2012 668.9*2=1337.8 so YES! remember RAM is Double Data Rate(DDR). it runs @ twice the frequency.
G gonzalopino25 Honorable May 17, 2012 17 0 10,510 Jun 6, 2012 #2 ASUS - Motherboards- ASUS P8P67 LE Upvote 0 Downvote
B brandonkick2005 Honorable May 16, 2012 13 0 10,510 Jun 6, 2012 #3 According to what I see your ram is running at PC3-10700 (667) MHZ. It should be running right at (but probably a little less) 1.5V Upvote 0 Downvote
smorizio Titan Jan 22, 2010 30,984 9 125,315 Jun 6, 2012 #4 the max rated speed in the spd is 667 or 1333. if you want it to run at 1600 or try to in the asus bios under ai clocking you have to change the ram profile to xmp then save and reboot. Upvote 0 Downvote
M MKBL Splendid Nov 17, 2011 429 3 24,565 Jun 6, 2012 #5 668.9 x 2 = 1337.8 Double Data Rate Upvote 0 Downvote
G Guest Guest Jun 6, 2012 Solution #6 668.9*2=1337.8 so YES! remember RAM is Double Data Rate(DDR). it runs @ twice the frequency. Upvote 0 Downvote Solution
G gonzalopino25 Honorable May 17, 2012 17 0 10,510 Jun 6, 2012 #7 Best answer selected by gonzalopino25. Upvote 0 Downvote
