Hd 6670 is compitable with intex cabinet with bundled psu 450w?
sir
i am looking for buy HD 6670 graphic card for my system. please suggest HD 6670 is compitable or not.
my computer specification
Intel core 2 duo e 7500 @ 2.93 GHz
gigabyte g31 m es2l
Samsung 20 inch LCD monitor
4 GB ram
one 500 GB hard disk
one DVD writer Sony
intex cabinet with power supply 450 w
i m worry about my power supply . it a local brand and some information written here as
power supply smart it-2045s+
atx2.03
450 watt
20+4 pin;1SATA:3HDD:1FDD:1FAN
AC INPUT 220V 50HZ 5A
DC OUTPUT +3.3V:30A +5V:29A +12V:18A -12V:0.5A +5VSB:2A
4 answers Last reply
More about 6670 compitable intex cabinet bundled 450w
  1. I think you will able to run that card.. But your psu wont let you to upgrade anything further..
  2. Intex is a generic PSU brand and it can't be much trusted.
    It delivers 18A on the single +12V rail, which looks okay.
    Also, you have a G31 chipset which has a PCIe 1.0 slot for the GPU. Since the HD 6670 is a PCIe 2.1 card, it may have some issues with compatibility. A BIOS update could fix it, but it doesn't always do the trick.
  3. I just checked Gigabyte's website, looks like it could be compatible, but do note that there would be a limiting bandwidth, so the HD 6670 wouldn't be running at it's maximum potential.
    http://www.gigabyte.com/products/product-page.aspx?pid=3485#bios
    Assuming that is your motherboard.
    But firstly, do check the version of BIOS that you are currently running.
  4. thanx guy for your valuable iinformation.. so which graphic card should be best for g31 chipset..pls suggest.
Graphics Cards Power Supplies HD Graphics
