Hey guys,
I just finished my first ever PC build. I thought it was going well, but after I finished and I powered the computer on everything seems to come on with no problems. The CPU fan, the case fan, and the video card fans all come on and I have the green LED on on the motherboard, but by my RAM there is another surface-mounted LED and this lights up red as this PC powers on.
I did some research on the problem, and I came to the conclusion that I either got faulty RAM or a faulty motherboard. I'm going to copy and paste a list of the parts I used below. I want to send the faulty part back ASAP, so I just want to know if there is any way I can test either the Mobo or the RAM to figure which is my problem.
ntel i5 3570k Ivy Bridge CPU - $189.99
http://www.microcenter.com/single_product_results.phtml?product_id=0388577
ASUS P8Z77-V PRO ATX Intel Motherboard - $169.99
http://www.microcenter.com/single_product_results.phtml?product_id=0386887
HIS IceQ Radeon HD 7850 Video Card - $249.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161405&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=s4deakg7knb4
Crucial M4 2.5" 128 GB STA III MLC Internal SSD - $123.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
G.SKILL Ripjaws X Series 8 GB RAM - $46.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=13sb8tbur0ee1
Seagate Barracuda 1 TB 7200 RPM Internal HDD - $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Windows 7 Home OS - $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=nh537jz27fyt
SAMSUNG DVD Burner - $16.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151244
Seasonic M12 2 620 W Power Supply
ASUS Backlight Widescreen LCD Monitor - $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236176
