EVGA 560 ti 2048 Power issue
I recently have upgraded my system in order to benefit from NVIDIA surround. After installing the second card setting up the EVGA 560 ti SLI configuration I finally ran Star Wars: The Old Republic. After seeing the graphics come on the screen I here my HDD stutter (not the HDD the system is running off of, system is on SSD) and the game locks up. My computer reboots and I get the BC Code 1000007e. I am currently running a Eagle Voltas ET-PSVT600E 600Watt ATX12V Power Supply. Now my question is, is this a power issue? From all the reading I have done I have found that it is. I went ahead and ordered a KingWin Lazer Power Supply 1000 Watts. Should I be okay or is this something else?
System specs:
CPU : Intel Core i5-650
mobo: BIOSTAR T5 XE CFX-SLI
RAM : G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
Video: 2x EVGA 560ti 2048
1 answer Last reply
More about evga 2048 power issue
  1. probably it is a power supply problem yes, looks like a quite generic PSU, and it is not in the Certified PSUS list for 560ti>
    http://www.geforce.com/Active/en_US/en_US/pdf/PSU.pdf
    so i would strongly advise you to change your PSU even if that isn't the problem for now. if you want to know what psu to buy check on that list of certified SLI psus.
    i recommend you Corsair brand, they are very stable and great price/performance
Graphics Cards EVGA Graphics
