After finishing school for the year ive decided i want to put together a gaming computer. Something capable of playing skyrim, battlefield, and mass effect on max settings. Im not looking for the cheapest parts. Just something very reliable. In all i would like to spend around a thousand dollars. I would need to buy the tower, a monitor, and a keyboard. Im looking for suggestions and details on what parts i should buy and use to create the best performance per dollar. If anyone know what parts i should use please let me know your thoughts. Thanks in advance
Approximate Purchase Date:Within 2 weeks probably.
Budget Range:After everything around 1000 dollars
System Usage from Most to Least Important:Gaming, homework, day to day use.
Parts Not Required: wont need a mouse.
Parts Required: The computer, a monitor, and a keyboard.
Preferred Website(s) for Parts: Whoever has the best deals. Probably newegg.
Countryont really care.
Parts Preferences:No biggger than a 24 inch monitor, 20" or 22" would be fine
Overclocking:Maybe, i dont think i need it.
SLI or Crossfire:Maybe, dont think i need it.
Monitor Resolution: Best possible for the price range. Something that can get max settings on battlefield, if possible
