Solved
HELP WITH GRAPHICS CARD!
Best solution
Graphics card Authority
Yes, it's above and beyond a 7600.
You're most likely looking at minimum specs. The GT 240 is a newer card, so it's not going to be listed on an old game. Your card is above and beyond the requirements.
Cheers!
Ask the community
