TrillyMix
6
Can anyone please check this out and rate it:
---CPU 349.99 Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
---MB 209.99 ASUS P8Z77-V PRO LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
---RAM 49.99 Kingston HyperX Blu 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3B1K2/8GX
---CASE 49.99 Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
---POWER 49.99 RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Power Supply, New Version with Build- in LED Fan On/Off Switch
---COOLER
---HDD 99.99 Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
---VIDEO 149.99 EVGA GeForce GTX 550 Ti Superclocked
TOTAL 959.93
I just want to see if everything is good and compatible with each other. Thanks for any help!
cranked
520
Everything is "compatible", but it's an odd build.
What is your budget? What is the purpose of the build?
Please fill out the "how to ask for advice" sticky at the top of the forum so we can help you better.
Odd doesn't even begin to explain that build.
TrillyMix
6
My budget is around $1,000. I plan on using this computer to game on Steam, video editing, stuff like that.
here is the advice thing:
Approximate Purchase Date: Doesn't matter
Budget Range: $1000
System Usage from Most to Least Important: 3d editing/rendering, vegas pro editing, steam games, web, email, etc
Parts Not Required: moniter, mouse, keyboard
Preferred Website(s) for Parts: newegg
Country: US
Parts Preferences: Intel
Overclocking: Maybe
SLI or Crossfire: No
This is a few dollars over your budget, but you can remove that cpu heat sink from this build to knock it down some in price and if and when you decide to over clock then pick it up then.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.964659 $174.98 save: $15.00 - $20.00 Mail In Rebates FREE SHIPPING
OCZ ZT Series 550W Fully-Modular 80PLUS Bronze High Performance Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom
ASRock Z77 Pro4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.asrock.com/mb/Intel/Z77%20Pro4/ <----- another look at that board along with a link to the latest bios
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501 $349.99 FREE SHIPPING
http://www.amazon.com/gp/product/B005O65JXI/ref=ox_sc_act_title_1?ie=UTF8&m=A2EUTVCJXLAJ4K $34.62 & this item ships for FREE with Super Saver Shipping
Cooler Master Hyper 212 EVO CPU Cooler (RR-212E-20PK-R2)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226272 $89.99 FREE SHIPPING
Mushkin Enhanced Blackline 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 993995
http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST1000DM003/dp/B005T3GRNW/ref=sr_1_5?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1339188676&sr=1-5 $89.99 & this item ships for FREE with Super Saver Shipping
Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
http://www.amazon.com/Asus-24xDVD-RW-Serial-Internal-DRW-24B1ST/dp/B0033Z2BAQ/ref=pd_cp__2 $21.48 & eligible for FREE Super Saver Shipping on orders over $25
Asus 24xDVD-RW Serial ATA Internal OEM Drive DRW-24B1ST (Black)
http://www.amazon.com/gp/product/B0050I1PGU/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0050I1PHO&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0M9QSJMQM8FTSNG934D4 $169.99 & this item ships for FREE with Super Saver Shipping
EVGA GeForce GTX 560 Superclocked 1024 MB GDDR5 PCI Express 2.0 2DVI/Mini-HDMI SLI Ready Graphics Card, 01G-P3-1463-KR
http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/ref=pd_bxgy_e_text_c $99.99 & this item ships for FREE with Super Saver Shipping
Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack
Total: $1,031.03 *not including rebates
http://www.amazon.com/Technologies-TEMPEST-210-Massive-Midtower/dp/B0066130CM/ref=sr_1_20?s=pc&ie=UTF8&qid=1339189012&sr=1-20 $54.99 & this item ships for FREE with Super Saver Shipping
NZXT Technologies TEMPEST 210 Massive Mesh Style Midtower Case with USB 3.0
