Hello,
So I am trying to help my brother with setting up his three monitors on his 5870. We have two DVI's and one DisplayPort -> DVI and thats the current setup.
Yet for some reason, windows will not allow all 3 to work at one. If I want monitor 1 and monitor 2 thats fine but it wont allow monitor 3 to be added and if I want it to be added I need to disable one of the other two (monitors 1 or 2).
I have a feeling it might be the display port but I am not really sure how to check this. I also went into CCC and when I want to make a group for EF, it only allows me to do a 2 monitor setup.
If you could help me with this I would be very grateful!
Thanks again,
Eli
Thanks again,
Eli
