T TT2_dut Honorable Apr 11, 2012 1 0 10,510 Apr 11, 2012 #1 Hi all, Since I purchased an Samsung SyncMaster 2433BW I keep getting error messages, that is: Not Optimum Mode 1920x1600 60Hz The problem: I have this set. It is some kind of software fault, but there are no drivers availible. What can I do best?
Sunius Splendid Dec 19, 2010 9,588 0 31,960 Apr 11, 2012 #2 What cable are you using to connect the display? You need to set resolution to 1920x1200 as that's the only resolution your monitor supports. Not 1920x1600. Upvote 0 Downvote
