Do you want to check your local wireless speed, or your connection to the internet?
If you want to check your local wireless local area network, the easiest way is to transfer a file between two computers on your local wireless. There are further utilities you can use, but before I look one up for you, I'd rather know that is what you want.
If you want to check your connection to the internet, try:
speedtest.windstream.net
