Hello! I need some help with my fist build. I am a bit worried about doing it so I came here for help. I hope you can help me, I've done some work myself (spent a few weeks) but I am not 100% confident if it will be fine. I hope you will be kind enough to help me out a bit.
I'll start off with some information, then I'll mention what I have and lastly
I will put up some questions that I am unsure about.
Approximate Purchase Date: In a week or 2.
Budget Range: upto about €1300
System Usage from Most to Least Important: playing games, and everyday things such as using the internet or writing something in wordpad + maybe programming in the future.
Parts Not Required:
■ Monitor, i have Dell Ultrasharp U2312HM 23 inch IPS LED Monitor
■ speakers
■ headset
Preferred Website(s) for Parts: Amazon.Co.Uk, Scan.Co.Uk - - - I live in Ireland, Co.Cork, but there are nearly no shops that sell computer parts so i need to order online, and the shops i know of are these 2, if you know any other shops i could look into, please let me know.
Parts Preferences: I've no really any preferences with the companies but I'd like an intel processor and a GeForce graphics card. The companies after that don't really make a difference to me aslong as they have good reputation.
Overclocking: Maybe in the future
SLI or Crossfire: Most likely no, but you can never be sure of that.
Monitor Resolution:
Dell Ultrasharp U2312HM 23 inch IPS LED Monitor 1920 x 1080
Additional Comments:
■ I would like a quiet enough computer (doesn't have to be silent)
■ I'd like everything staying at low temperatures
■ I'd like the computer to last a good few years
■ I don't live in a very hot country so the temperatures should stay low enough (if i am wrong on this then please correct me)
~~~~~~~~~~ Parts I have Picked myself~~~~~~~~~~
Motherboard: Asus P8Z77-V PRO
RAM: Corsair CML8GX3M2A1600C9B LP Vengeance Memory 8GB (4GB X 2) 1600MHz CL9 DDR3
HDD: Western Digital Caviar Black 1 TB 7200 RPM
Case: Antec Nine Hundred Two V3
Processor: Intel 3rd Generation Core i5-3570K CPU
Processor cooler: Coolermaster Hyper 212 EVO
Graphics Card: Asus 2GB GeForce GTX 670 DirectCU II
PSU: Corsair AX 650W Professional 80 Plus Gold Modular Power Supply
Keyboard: Razer Blackwidow
Mouse: Razer Deathadder Re-Spawn 3500DPI
Things I am unsure about:
■ Is the motherboard worth getting? Or are there better ones for similar price or lower?
■ Is the HDD worth getting, or should i get like 2TB for the same price but the 2TB will be those eco-friendly.
■ Will everything fit in the case?
■ Is the graphics card i put up good? or should i go with maybe EVGA or a different company?
■ Will the PSU be enough for the build? I probably won't be adding much in the future, maybe extra storage but that's about all.
■ Will the parts stay at a safe temperature?
■ Do You Have Any Other Suggestions?!?
■ Can you also suggest a cheap Optical drive, i will probably use it to install games and the OS and maybe burn a CD once in a while.
■ does it matter which thermal paste i get?
I hope you can help me with that much (and I didn't bore you with all the writing). I am looking forward to your reply and ideas!
Thanks In Advance!
Parts Not Required:
■ speakers
■ headset
Monitor Resolution:
Thanks In Advance!
