Closed Solved
Hp S2031 monitor help
can someone please help me fix my monitor. it may be defective but i don't know. so let me layout the situation for you guys:
1) im just using my computer perfectly, then it freezes or i accidentally shutdown <---at this point screen works perfectly
2)so i try to restart my computer, the screen refuses to get any input signal and all it says is no input signal found , check your cable....<-- obviously checking the cable didn't help my problem
3)so i resort to a more extreme method of trying to get it to work to no avail. i just overload the computer with turn on and off requests<--- still doesn't work
4)give up on the computer...
basically i just need help to make the screen restart immediately after i restart or it freezes
my monitor: is an hp s2031
graphics card: nvidia graphics card(geforce 6200 LE)
http://dl.dropbox.com/u/9466865/hardware.bmp
http://dl.dropbox.com/u/9466865/mainboard.bmp
http://dl.dropbox.com/u/9466865/processor.bmp
http://dl.dropbox.com/u/9466865/properties.bmp
thank you in advance for helping me fix this vexing problem :wahoo:
oh and yeah i put it in the graphics card section bcuz i think it may be caused by my graphics card/ video card idkthough
2 answers Last reply Best Answer
More about s2031 monitor help
  1. Best answer
    remove the 6200 le and connect ot the internal graphic card if syystem work then the extension card is defective you will need a new one but in the same specs of the 6200 le
  2. Best answer selected by amskhan.
Graphics Cards Computer Monitors Graphics
