Im going to buy this barebones kit: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5051182&CatId=5291
but I have some question about the PSU concering this graphics card
http://www.amazon.com/Force3D-radeon-graphics-express-windows/dp/B006OS6UAG/ref=sr_1_11?s=electronics&ie=UTF8&qid=1349714496&sr=1-11&keywords=radeon+hd
I was wondering if it will work effeciently with all the other parts of the barebones kit minus the GPU that comes with it.
MSI 760GM-P23 (FX) AMD Series Motherboard - Micro ATX, Socket AM3+, AMD 760G, 1333MHz DDR3, SATA II (3Gb/s), RAID, 7.1-CH Audio, Gigabit LAN, USB 2.0
AMD ADX640WFK42GM Athlon II X4 640 Quad Core Processor - Quad Core, 2MB Cache, Socket AM3, 95W, No Fan, OEM
Cooler Master RR-B10-212P-GP Hyper 212 Plus CPU Cooler - 120mm, LGA 1366, 1156, 775, AMD AM3, AM2+, AM2
Corsair CMX4GX3M1A1333C9 XMS3 4GB DDR3 RAM - PC10666, 1333MHz, 4096MB
MSI Geforce 8400 GS N8400GS-MD512H/TC Video Card - TurboCache 1GB, 512MB DDR3, PCI-Express 2.0(x16), 1x Dual-link DVI-I, 1x VGA, 1x HDMI, DirectX 10, Low Profile
Samsung SH-222BB/BEBE 22X Internal DVDRW Drive - SATA, 1.5MB Buffer, 22x DVD+/-R, 8x DVD+/-RW, 16x DVD+R DL, 12x DVD-R DL, OEM, Black
Ultra XBlaster Mid-Tower V2 Case - ATX, MicroATX, USB 2.0, Audio, 6x 3.5" Bays, 3x 5.25" Bays, 7x PCI Slots, Includes 450W PSU, Lifetime Warranty with Registration
Kingwin CFY-012LB Advanced Series 120mm Yellow LED Case Fan - Long Life Bearing, 950 RPM, 3 Pin /4 Pin Connector
Im not sure how PSU work, but I looked at the little power specification chart and it said all this. And I heard you only want to run at 80% of the PSU or something.
If that graphics card won't work, can you guys fiind me one thats around $50-$60 and can handle assassins creed and gw2 and stuff. Thanks!
This is the specs of the PSU that comes with the barebones kit
