Solved
Help with power supply wattage, and part choice.
Approximate Purchase Date: A couple weeks from now
Budget Range: $620
System Usage from Most to Least Important: Gaming
Parts Not Required:mouse, keyboard, monitor, hard drive, cd drive
Preferred Website(s) for Parts: amazon, or newegg (whichever one is cheapest)
Country:Us
Parts Preferences: Intel, Amd ati, asrock, corsair
Overclocking: maybe
SLI or Crossfire: no
Monitor Resolution: 1920x1080
Additional Comments:none
Parts:
i3 2120
sapphire radeon hd 6950
asrock z68 pro3 gen3
corsair vengeance 1x4 gb 1600Mhz
cooler master storm scout
My question is, are these parts a good choice, and will this power supply be sufficiant?:
http://www.amazon.com/gp/product/B004W2T2TM/ref=ox_sc_act_title_2?ie=UTF8&m=ATVPDKIKX0DER
(430 watts)
8 answers Last reply Best Answer
More about help power supply wattage part choice
  1. Best answer
    No. Get an XFX 550W.
    Budget Range: $620
    Country:Us
    Overclocking: maybe
    Parts:
    i3 2120
    (430 watts)
    If you change that HD 6950 to HD 7850, that 430W PSU will work.
  3. what if I upgraded it to 500w?
  4. It still won't work because the CX430 doesn't supply 430W.
  5. so what does it supply?
  6. In the 300 watts range.
  7. O.o what power supply do you reccomend for around the same price?
    Edit: Will an xfx atx 450watt do the job well?
  8. Best answer selected by 64bitgenius.
New Build Systems
