Finally gave in to my friend telling me to build my own computer so this will be my very first build. Very hesitant to buy the parts without some expert opinions. This is what I came up with from doing some research on these forums and other various places.
My main goal is to be able to play Diablo 3 at full max settings and also future proofing the computer. If there are parts I can replace to save some money and still achieve my goal please let me know. Thanks!
Cooler Master HAF 912
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Intel Core iT-2500k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Asrock Z77 Extreme4 (Maybe to upgrade to the new Ivy Bridge later on)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
Corsair Builder Series CX600 V2 600W ATX12v v2.3 80 Plus Certified
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
EVGA 015-P3-1480-KR GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130759
New Build after advice taken from responses here and further research. Let me know if this is a good build for the money thank you!
Intel Core i5-2400
Asrock Z68 Extreme3 Gen3
XFX Double D HD-695X-CDFC Radeon HD 6950 2GB 256-bit GDDR5
Optical/HDD supplied from my older computer.
= $691.93 after rebates.
Intel Core iT-2500k
Intel Core i5-2400
