Building a system (or buy it)
BillThompson22
I've never built a computer before, did a little research, and do not need a graphics card. I use powerful business software and surf the web mainly, but may use this build as a media center. Intel HD 4000 will be more than enough. I do not need a keyboard or mouse.
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM $18.99
Antec Three Hundred Two Black Steel ATX Mid Tower $64.99
nMEDIAPC ZE-C68 All-in-one USB 2.0 Card Reader w/ USB Port $12.99
Antec 30300 Three Hundred 5.25" To 3.5" Drive Bay Adapter Assembly $12.99
Antec VP-450 450W ATX 12V v2.3 Power Supply $37.99
Seagate Barracuda 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive $99.99
Patriot Viper Xtreme Division 4 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) $87.99
GIGABYTE GA-Z77-D3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard $119.99
Intel Core i7-3770 Ivy Bridge 3.4GHz LGA 1155 Quad-Core Desktop Processor Intel HD Graphics 4000 $314.99
Microsoft Windows 7 Home Premium SP1 64-bit $99.99
Total comes out to $881
Or I could buy this for $899
http://www.newegg.com/Product/Product.aspx?Item=N82E16883220155
Key difference is 2TB at 5400 RPM, and terrible stock power supply.
So should I build buy? If you believe I should buy the ASUS, what would you change with my build? I know i7 is overkill for what I need, but I want it!
