Solved
Driver USB Problem
I'm having a problem, i installed a catalyst beta driver long ago, now if i try to remove my new drivers to install a fresh new one, it removes a thing called AMD USB Driver And then my mouse and all other USB Devices stop working, does anyone know where can i get the Driver separated from Catalyst, or a fix to this ?
More about : driver usb problem
Best solution
Being these are Catalyst files, I trust your looking to update your video but some how the install is removing your usb driver? In any case, download the Catalyst installer. Run it to just extract the files but don't install. They will extract to a temporary location which you may need to search for if you don't have an option to choose one. From there you can use device mgr to select your device you wish to update and point directly to the files vs using the installer.
Ask the community
