These are the parts that I am using for my build:
Antec 110 Mid Tower
i5 3570K Ivy Bridge (Artic Silver 5) CPU
Xigmatek Dark Knight II Night Hawk Edition CPU Cooler
Asus Sabertooth Z77 Motherboard
Corsair HX 750W PSU
Mushkin Enhanced Blackline 8 GB 1600 MHZ
Plextor M3 128 GB SSD
Seagate Barracuda 7200 RPM 64 MB Cache 1 TB HDD
HiS IceQ 7850 GPU
I finally got around to building my first computer after months of researching parts and years of saving money. I think I did a fairly nice job hooking everything up for a first time builder, including cable management, even though it took me a really long time to do. And then the moment of truth came, plugging in the power and turning it on!
And alas, it booted up to the BIOS screen! My RAM was recognized at 1333 MHZ and I was easily able to set it up to 1600 MHZ in the UEFI BIOS. Then I installed Windows 7 x64 bit. No issues yet! Then I installed some ASUS Utilities from the Motherboard disc, and was beginning to install my network drivers so I could finish updating drivers for the rest of my equipment, when things went to hell.
My computer shut it self down and restarted, and the error that presented itself was:
Power supply surges detected during the previous power on. Asus Anti-Surge was triggered to protect system from unstable power supply unit! Press F1 to start setup.
Then the problems got worse from there... It loaded Windows and restarted itself with the same error several times. I Googled the problem from my phone, and numerous things come up with that error. I tried to turn off the Asus Anti-Surge protection in the BIOS, but I could not find it, and finally, the computer won't turn on at all, not even the fan on the power supply.
When I go to push the power button on the computer, I see the LED for CPU Cooler try to start on, and it immediately fizzles and turns off. The Standby LED on my motherboard is lit up solid green, but it won't start up. When I plug in my old 400W Dynex power supply, the computer will at least power up.
Before I RMA'd the power supply, I went to a local computer store and they tested the power supply, and they said it was running fine. So now I am stuck, and have no idea what to do, or what the problem is (power supply, motherboard, enough power from the wall, etc.). I have taken the entire computer setup around the house trying different plugs in the house, I'm pretty convinced that's not the issue.
At this point I am sick and absolutely regret not buying a prebuilt machine from a reputable company.
Antec 110 Mid Tower
Corsair HX 750W PSU
HiS IceQ 7850 GPU
