Are the parts for my computer build compatible?
These are the final plans for my PC build.
I would like to check one (hopefully) last time to make sure all the parts I've picked are compatible.
So, are the parts compatible? Are the dimensions correct?
Mother Board:
ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157265
Random Access Data (RAM):
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9Q-16GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231456
Central Processing Unit (CPU):
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&Tpk=Intel%20Core%20i5-2500K%20Sandy%20Bridge%203.3GHz
Solid State Drive (SSD):
Crucial M4 CT128M4SSD2CCA 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) with Transfer Kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
Graphics Processing Unit (GPU):
SAPPHIRE Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card (11200-00-20G)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102986
Power Supply Unit (PSU):
SeaSonic X750 Gold 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=17-151-087&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
Hard Disk Drive (HDD):
Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136792
DVD Burner:
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Computer Case:
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
CPU Cooler:
XIGMATEK Dark Knight II SD1283 Night Hawk Edition CPU Cooler with Stealth Aerospace Industry Thermal conductive ceramic coating ALL intel AMD IVY BRIDGE compatible
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Thank you all for the advice.
4 answers Last reply
More about parts computer build compatible
  1. Compatible yes , smart: NO
    could you explain?
  3. Get this motherboard instead: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
    16GB of RAM is OVERKILL for gaming; go for 8GB.
    Everything else is fine.
    However, honestly if you are spending that much money get this video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787
  4. Budget?
New Build Systems Product
