Greetings hardware community.
I'm looking at starting my first build, but before I go purchasing all the hardware I'd like to get a few recommendations/overviews of my parts list. Please note this computer will be used for light gaming (mostly Diablo 3), surfing the net, and movies here and there.
Mobo: ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
CPU : Intel Pentium G860 Sandy Bridge 3.0GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics BX80623G860
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116405
GPU : SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity (100315L )
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
PSU : CORSAIR Builder Series CX500 V2 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
MEMORY: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
HDD : Western Digital RE4 WD5003ABYX 500GB 7200 RPM 64MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
Case : Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LEr D 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
As for right now everything falls under my $600 budget including all rebates. I do however have a few future upgrades I would like.
Future options:
Intel i5 2500
Xfire 6850
Samsung 120GB SSD
I do understand that I probably should just go this route from the start, but breaking the budget just isn't in the books. Please let me know what you think and an other recommendations that would stay within the budget.
Thanks for your time.
Future options:
Intel i5 2500
Xfire 6850
Samsung 120GB SSD
