G
Guest
Guest
I am planning to build a gaming PC at a cost between $2,000 and $2,200 early next year. I know that I want a THX-certified sound card to connect to my Logitech Z623 computer speaker system. The only other major thing that I will be doing with my future PC is listening to music files in the FLAC format. I am looking at the THX sound cards made by Creative and have the following questions:
1. Would I get noticeably better sound quality using THX-certified RCA audio cables with a THX-certified sound card that has RCA plugs than a cable and THX sound card with a 3.5 mm jack and plug?
2. Are there any other reliable sound card companies that make THX-certified sound cards?
