I know I should have looked into this sooner but just wanted to make sure I am not running to hot CPU temp wise.
1.Currently have AMD Phenom II X4 3.41ghz it runs around 40c / (102F) is that to hot!?
2. Upgrading to a AMD FX 6100 3.1 not a huge upgrade just thinking I need to do it cause I have a glitch issue where my computer will lag and ghost kind of the mouse will be unable to control for a few seconds. I replaced everything on my computer so far and the issue is still not fixed for it must be the cpu I am guessing or monitor.
Updated bios and all that also..seems like it has not helped much. Tho updating bios that one that came out this month did not make it nearly as bad as it was.
Now when playing Diablo III I have few issues. I have the most issues when playing League of Legends online,get real bad ghosting of the mouse. I have a Logitech MX518 mouse. Also it makes a noise like when you plug a device into a USB port,sometimes it will make that noise.
Kind of went off on a tangent!!Ill post question "2."Ill put it under another thread most likely just thought I try it out here also cause it seems to be related.
