I currently have an extra monitor that i would like to connect to my current system to use as an extended display. My current pc specs are
X2 250
Radeon 3450 http://m.bestbuy.com/m/e/product/detail.jsp?skuId=3930922&ref=06&loc=01&ci_src=14110944&ci_sku=3930922&pid=1218443196605#product-overview
4gb ram
500gb 5400rpm hd
Both of the monitors are vga but the 3450 has a vga and a dvi i. If i got an adapter to go from dvi i to vga and hooked up the second monitor would it work? My main question is could my system handle it? Can the 3450 handle two displays if i they are not being used for gaming and is it even compatible at all? Thanks in advance.
X2 250
4gb ram
500gb 5400rpm hd
