Can i start GTX 560 TI at this power supply ?
can i start GTX 560 TI at this power supply ?
his stats:‎ ‎
TR-500P‎
Type‎ ‎ Intel ATX 12V 2.3‎
Output Capacity‎ ‎ 500W‎
Max. Output Capacity‎ ‎ 550W‎
Color‎ ‎ Black‎
Dimension ( W / H / D )‎ ‎ 150mm x 86mm x 140mm‎
PFC (Power Factor Correction)‎ ‎ Active PFC‎
Power Good Signal‎ ‎ 100-500 msec‎
Hold Up Time‎ ‎ 16msec (minimum) at 80% of full load at 230Vac input‎
Input current‎ ‎ 6A@115Vac, 3A@230Vac‎
Input Frequency Range‎ ‎ 47Hz ~ 63 Hz‎
Input Voltage‎ ‎ 115Vac- 230Vac‎
Operation Temperature‎ ‎ 10 ℃ to +40 ℃‎
Operating Humidity‎ ‎ 20% to 90%,non-condensing‎
Storage Temperature‎ ‎ -20 ℃ to +70 ℃‎
Storage Humidity‎ ‎ 5% to 95%, non-condensing‎
Cooling System‎ ‎ 2400±10%R.P.M.‎
Efficiency‎ ‎ Over 78% efficiency @ 115VAC input‎
‎ Over 80% efficiency @ 230VAC input‎
MTBF‎ ‎ 100,000 hrs minimum‎
Safety Approval‎ ‎ UL, CUL, TUV, FCC, CE, GOST and BSMI certification‎
PCI-E Connector‎ ‎ 6Pin x 1‎
‎ 6+2Pin x 1
3 answers Last reply
More about start power supply
  1. Should be okay, what are the other specs of your comp?
    CPU:I5 3.2
    RAM:8GB
    GPU:geforce 9800GT
    PCI-E x16 v2.0
  3. 500W is enough to power a single GTX 560 TI, but you should not overclock the CPU.
Graphics Cards Gtx Power Supplies Graphics
