xd card speed
Forum Digital Camera : Digital Camera General - xd card speed
Archived from groups: rec.photo.digital (More info?)
I have been trying to understand the ratings on digital camera cards.
They give the write speed and the read speed, which I understand, but
what determines the speed rating.
I was looking at the xd-picture card 128 mb the ratings are specified
as:
speed rating: 130x
write speed: 3MB/s
read speed: 5MB/s
Thanks in advance for your time and effort regarding this question,
Linda
Sponsored Links
Essentially, testing the card in the fastest card reader and
seeing what it's speeds are for sustained read and write operations
using large files. When used in a camera, PDA, or MP3 player, the
device's limitations will often prevent the card from reaching its
maximum rated speeds.
> as:
> speed rating: 130x
> write speed: 3MB/s
> read speed: 5MB/s
That's about right for the write and read speeds, since my 1GB xD
card is rated at 3.5 MB/s & 5 MB/s. But I don't know where they got
the 130x figure. The basic rate used to calculate that is 150kb/s.
So a 4x card is 600kb/s, a 40x card is 6MB/s and so on. So using
its fastest rated speed (5MB/s for read operations), the card should
probably be labeled as a 33x or 34x card. A true 130x card would
indicate a throughput of nearly 20GB/s, whereas most (not all)
cameras never reach 2 GB/s speeds. So it's unlikely that you'll
want or need a faster card unless you have a USB 2.0 high speed card
reader that will let you copy files faster than 2 GB/s to your
computer, or until faster cameras that use xD cards are produced.
Reply to Anonymous
Which camera are you using ?
Alfred Molon
Olympus 4040, 5050, 5060, 7070, 8080, E300 forum at
http://groups.yahoo.com/group/MyOlympus/
Olympus E300 resource - http://myolympus.org/E300/
Reply to Anonymous
Thank you for responding with such great detail. I now have a better
understanding what is meant by that rating.
I have a fuji finepix s3100. It appears to me that the fastest xd
cards available are the 3mb/s - 5mb/, would that be correct? I had
read that the quality of the photo would be determined by the quality
of the card you purchase. The faster it writes, the less likely it
will blur in low light. I have seen sd cards get as high as 20mb/s,
but have not found any xd cards go that fast. Thanks again for your
time and effort, it is greatly appreciated, Linda
Reply to Anonymous
Totally wrong. The quality of the images is determined by the
camera's lens and sensor. The card is used by the camera AFTER the
image is captured, so if it takes more time writing to a slower
card, time is all you'll lose, not quality.
Reply to Anonymous
And BTW, you missed my point about card vs. camera speed. If you
could get an xD card that reads and writes at (up to) 30MB/sec, that
would only be its maximum in suitable devices. You camera does not
have the ability to write as fast as 3MB/sec no matter what current
or future card you use, so don't worry about the speed of any xD
cards unless you get another camera, possibly 2 to 3 years from now.
Then, the P&S cameras may be able to write faster then 3MB/second.
Reply to Anonymous
In article <1122234945.659406.3980@z14g2000cwz.googlegroups.com>,
calicoharbor@aol.com says...
The card you use has absolutely NOTHING (once again: nothing) to do with
the quality of the images.
And by the way, I know of no camera which can write to an xD card faster
than 1-1.5MB/s.
Alfred Molon
Reply to Anonymous
Duly noted. I get it. No camera as of this date and time can write
faster than 1-1.5MB/s. Any card over 3MB/s would be of no use to a
camera of this date and time. The write speed has nothing to do with
quality.
At the risk of sounding like a complete idiot, do I dare ask how the
camera catches the picture? Where does it hold the picture as it is
being written on the card? Doesn't it make a little sense that if
the image was written faster on the card that it would cut down on
images blurring in a low light setting? Sort of like 35mm film that
had different speed of film, like 200asa or 400asa. I am not a huge
camera person, and I admit I don't know what I am talking about half
the time. I just pick up little bits and pieces of information and I
am just trying to figure it all out. I truly appreciate your help,
Lind
Reply to Anonymous
On 24 Jul 2005 18:45:26 -0700, calicoharbor@aol.com <calicoharbor@aol.com> wrote:
> Lind
Here's a simplified outline of what happens when you take a picture:
Inside the camera, there's a sensor that records the light. In a film
camera, the sensor is the film; in a digital, the sensor is a fancy chip
with several million little detectors. Covering this sensor is a
shutter, which is normally closed, preventing light from the lens from
hitting the sensor.
When you press the button to take a picture, the shutter opens, allowing
light to hit the sensor. After a certain amount of time, the shutter
closes, completing the exposure. This time is determined by the camera
based on how bright the area is. If you're outside in broad daylight,
it'll be a very short time, 0.005 seconds or faster. At night, it could
be several seconds. This is the exposure time, and the camera has to
remain stationary during it or you'll get a blurred image. At this
stage, the image data is contained on the sensor, and hasn't been moved
into the camera's memory.
After the exposure is finished, the camera's processor reads the
information off the sensor, converts it into a format that your computer
can understand, and saves it to the memory card. This happens as
quickly as the camera is capable of, which depends on your camera and
the speed of your card. Shaking the camera is irrelevant at this stage,
since it's just a small computer crunching numbers and moving data
around. A faster card doesn't do anything to reduce blurriness, but it
does mean that the camera can finish all of the processing faster, and
be ready to take another shot more quickly.
-dms
Reply to Anonymous
> quality.
There are several cameras that can write faster than 1.5MB/s. But
not your camera, and of those that do, probably all or most of them
are DSLRs. Some cameras benefit from cards faster than 8MB/s.
The image is captured by the sensor, which is in the same location
that film would be in if it was a film camera. It doesn't make
sense that writing faster to the card would reduce blurring, because
no writing can occur until long after the shutter closes. The
shutter stays open long enough to collect sufficient light. If it's
very dim, it has to stay open longer to collect enough light
(photons) to record a decent image. If you handhold the camera,
there will always be some blur, but if the shutter speed is fast
enough you won't notice it. The longer it stays open, the greater
the amount of blur. Once the shutter closes, whatever blur exists
is already captured by the sensor. Then the camera starts
processing and copying the image to the card. If the camera was so
slow that it took 30 minutes to copy the image to the card, it
wouldn't add a bit of blur to the image, other than the amount that
it always intentionally adds. (don't ask, it's a normal part of the
camera's processing of the images, and is too small to easily see)
Reply to Anonymous
Hmm, you've been around cameras a while, I think. When I started
film using cameras, ASA was used. It isn't used with digital
cameras though, which refer to ISO instead. But they're basically
the same thing. If you want to reduce blur, you'd set the camera to
use ISO 400 instead of ISO 200 or ISO 100. It works the same way
it does with film cameras. It indicates greater sensitivity to
light, and allows the camera to use a faster shutter speed, reducing
blur.
Reply to Anonymous
I had no idea that the image is captured on a sensor. I can clearly
understand why the speed of the card is not relevant. I've only been
around people who talk about cameras and learn bits of stuff from time
to time. I am strictly a point click person and would never be able to
use a DSLR. I guess I got a hold of some bad information, that seemed
to make sense to me, but it is clearly out of the ball field. Thanks
for taking the time and painting a perfect picture for me!
Best Regards,
Linda
Reply to Anonymous
On 24 Jul 2005 20:06:15 -0700, calicoharbor@aol.com wrote:
> I am strictly a point click person and would never be able to use
You're welcome. But your S3100 is a nice little camera (I have
the similar S5100) If you use it enough so that you feel very
comfortable with it and eventually learn how to use most of its
features (especially its Manual Mode) you'd be more advanced than
some DSLR owners that only use them in Auto Mode. But there's no
need to get bogged down learning all of the fine points unless or
until you start taking some pictures that you think could have come
out better and want to figure out what it takes. If you're already
pleased with your pictures, as the song goes, "Don't worry, be
happy." :)
Reply to Anonymous
Tom's Hardware > Forum > Digital Camera > Digital Camera General > xd card speed
There are 1158 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
