Ok, im going for a build and i need some help to cut costs, my budget is $1400 MAX
here it goes:
CORE: Intel Core i5 2500 ($270)
GPU: EVGA GTX 560 SC ($255)
PSU: Corsair 750w TX750 V2 80 plus Bronze ($148)
RAM: Corsair vengeance 8gb(4gbx2) 1600mhz ($70)
HD: SEAGATE SATA-3 500GB ($92)
CASE: Cooler Master ELITE 371 ($49)
FANS: Cooler Master 140mm x 140mm x3 ($36)
SCREEN: LG LED 22" IPS226V
NOTE: I LIVE IN PERU, PRICES ARE HIGHER
Any recommendations about the MOBO? i wont overclock this build so i need something cheap but reliable that works with all this pieces
here it goes:
