Archived from groups: rec.photo.digital (More info?)
Hi - I have had a Nikon Coolpix 4500 for 18 months with absolutely no
problems. I went to turn it on today and - nothing! The green light did
not come on and the camera did not power up. Thinking bad thoughts
about the battery, I replaced it with a fully charged battery. Still no
luck. Is there some sort of power switch override or fuse or other
control that I am missing?
On 24 Jul 2005 16:27:17 -0700, in rec.photo.digital "nkbay"
The rotary switch on the 9xx/4500 is notorious for needing some cleaning
after a while. Try some Radio Shack Tuner Cleaner judiciously applied and
rotate the switch back and forth. Then place the camera so the top of the
switch is down to allow any cleaner to flow out on a paper towel.
Ed Ruf Lifetime AMA# 344007 (Usenet@EdwardG.Ruf.com)
See images taken with my CP-990/5700 & D70 at
http://edwardgruf.com/Digital_Phot [...] index.html
