This is the *GAMING* computer that I am hoping to build:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066&Tpk=11-129-066
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837&Tpk=13-131-837
Power supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115092
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820104173
*I have a HD already so no need to buy another one.
GPU: Nvidia GTX 550TI
I went over the pictures on some of the products to check and see. They all seem fine but I want to know if all of these products will go into this case/motherboard with a nice fit and not some extremely tight fit.
*Also note that I am on an extremely tight budget with this build*
