Using a Y splitter for case fans
  • Power Supplies
  • Cases
  • Cable
  • Components
Last response: in Components
October 13, 2012 9:13:20 AM
I have a splitter cable that has 1 plug that fits into a 6 pin 12v slot on my PSU and splits into two molex cables. Can I plug two fans into that and will that be ok? I noticed that the molex cables on the splitter only has 3 pins, what is the difference between 3 and 4 pin ones?
More about : splitter case fans
a b ) Power supply
October 13, 2012 2:40:54 PM
fans are really low power.
m
l
a b ) Power supply
October 13, 2012 8:51:36 PM
there isnt much of a problem. you would only run into a problem when you are using 5500rpm delta fans which draw 15w a piece
m
l
October 13, 2012 9:37:34 PM
should be fine, I asked a similar question awhile ago, I would just make sure both fans power draws don't exceed 1amp total unless stated other wise in the mobo manual. Most fans wont ever use even 0.5 amps unless getting some Ultra Kaze's or Delta.
m
l
