G
Guest
Guest
Hey everyone.
So, I just built myself a desktop, but the aftermarket CPU cooler I got (CM V6GT) ended up being too big of a cooler for my case, and the stock CPU cooler didn't come with the proper mounting brackets, so now I'm stuck having to buy another aftermarket CPU cooler.
My motherboard is an MSI 970A G46 AM3+ motherboard.
My CPU is an AMD Phenom II X4 965 Black Edition AM3 125W 3.4GHz CPU.
My case is a Cooler Master K350 mid-ATX case (though, it's kinda-of small for a mid-ATX case.)
Here are the CPU coolers I was looking at (I don't know if any of these coolers will fit onto my motherboard, so maybe you guys can tell me)
- Cooler Master Hyper 101A for AMD Socket
- Cooler Master Vortex Plus CPU Cooler for Intel Socket LGA1366/1156/775 and AMD Socket AM3/AM2/940
- Zalman CNPS10X Performa CPU Cooler 2 Ball Bearing 4Pin for Intel Socket 2011/1156/1366/775 & AMD Socket AM3/AM2+/AM2
- Zalman CNPS10X Quiet CPU Cooler 2 Ball Bearing 3Pin for Intel Socket 1156/1366/775 & AMD AM3/AM2+/AM2
- Cooler Master GeminII S524 CPU Cooler
Are any of these CPU coolers good enough to cool my X4 965 BE (preferably at around 35-40 degrees celsius???)
Which CPU cooler is the best out of this list?
Again, I have no idea if any of these are going to fit onto my motherboard, so if any of them can't, please let me know. I literally CAN'T afford to screw this up.
EDIT
Okay, so I guess my next questions are:
What are safe idle and max temperatures for an AMD Phenom II X4 965 BE @ stock 3.4GHz? The general consensus seems to be about 38-40 degrees celsius at idle, and 54-58 degrees celsius at max load, going no higher than 60-62 degrees celsius. Is that about right do you think, or am I way off?
Also, I've also done a bit of research on safe voltages for an X4 965 BE at stock speeds, and the general consensus seems to be 1.3-1.37v, going no higher than 1.4v (1.4v being quite unsafe, unless max temperatures are 55 degrees celsius or lower.) Am I about right, or am I way off?
EDIT
