Best power supply for gtx 670
i plan to upgrade my GPU from gtx 560 ti to gtx 670.. i already have corsair CX600 v2 but i don't think it can support enough for my new GPU.. can someone recommend the best budget PSU for GTX 670...
8 answers Last reply
More about best power supply
  1. Unless that 600W is also powering a death star it's more than enough for your new card.
    If you want a definitive answer though post your full specs
  2. nVidia itself recommend 500W for a single 670.Your PSU is compatible
    http://www.nvidia.in/object/geforce-gtx-670-in.html#pdpContent=2
  3. i5 2500k
    ASRock Z77 Extreme4-M
    gtx 670 gigabyte 3 fan ( future )
    1666 corsair vengence 4g x 2
    cooler master hyper 101
  4. hasnol said:
    i5 2500k
    Then yes its plenty you don't need new
  5. Your current PSU is enough.If you prefer a higher quality assurance that's understandable and i would then suggest
    Rosewill Capstone 650W
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182263
    Superflower made, 80Plus Gold, 54 amps of 12V power,modular, 5 year warranty
    Seasonic X650
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
    80Plus Gold, 54 amps 12V power, 5 yr warranty, FULLY modular
  6. Quote:
    thanx you for your information.. so, i can save my money.. yahoo!!!
  7. how can we now either the PSU is modular or non modular? what is the advantages?
  8. Modular lets you remove the cables you are not using so things look tidier
Power Supplies Gtx GPUs Components Product
