Tom's Hardware > Forum > Windows XP > Configuration & Customize > Problem with runservice.exe
Forum Windows XP : Configuration & Customize - Problem with runservice.exe
Archived from groups: microsoft.public.windowsxp.customize,microsoft.public.windowsxp.general (More info?)
I had a program installed previously - and it worked fine. At some point, I
uninstalled it. Now I reinstalled it and it won't run. I receive the error
message: runservice.exe has encountered a problem and needs to close. Can
anyone help? I'm using XP Pro.
Sponsored Links
this is related to spyware.
see http://www.2-spyware.com/file-runservice-exe.html
george
"+++Bobby "O"+++" <rmo555@cox.net> wrote in message
news:UdsMd.5$Bs5.3@lakeread07...
>I uninstalled it. Now I reinstalled it and it won't run. I receive the
>error message: runservice.exe has encountered a problem and needs to
>close. Can anyone help? I'm using XP Pro.
Reply to george
I downloaded the free version of SpyHunter - but it didn't find
runservice.exe. What should I look for? Also, I have Spybot and Ad-aware -
and they don't fix runservice.exe either. Can you give me any other help?
Thanks......
"george" <anonymous@discussions.microsoft.com> wrote in message
news:eX3t34gCFHA.3416@TK2MSFTNGP09.phx.gbl...
> george
Reply to Anonymous
look here http://startup.iamnotageek.com/src [...] e.exe.html
or here http://www.anti-spy.info/process/runservice.exe.html
or here http://www.auditmypc.com/process/runservice.asp
don't know if this applies to your situation
http://www.liutilities.com/product [...] unservice/
otherwise google for runservice.exe (where these came from too)
george
news:BFtMd.16$Bs5.14@lakeread07...
>Ad-aware - and they don't fix runservice.exe either. Can you give me any
>other help? Thanks......
>> george
>>>point, I uninstalled it. Now I reinstalled it and it won't run. I
>>>receive the error message: runservice.exe has encountered a problem and
>>>needs to close. Can anyone help? I'm using XP Pro.
Reply to george
If you're sure that it is spyware and the (anti-spyware) website leads me to
believe it is, then just search for that filename on your computer and delete
it. If it won't let you delete it because the file is in use, kill it with
task-manager (ctrl-alt-del).
Reply to homer
Hold it on the deleting part. It might be a required file. Try
run>msconfig>startup tab and uncheck it.
Reply to homer
[[Go to Start/Control Panel/Administrative Tools/Services. Look for a file
called LicCtrl and make sure it is set to automatic. This must be enabled
before the License part of the game will run.]]
Startup entry for runservice.exe: LicCtrl
runservice.exe description:
eLicense, licensing system incorporated with some software and games.
eLicense
http://www.elicense.com/
runservice.exe - Here is the scoop on RunService. The big question: what is
runservice.exe and is it spyware, a trojan and if so, how do I get rid of
RunService?
runservice.exe (RunService) - Details
The runservice.exe process is used with the eLicense copy protection system
that is used with certain programs/games. If this process is not running,
programs or games that use eLicense may not work. So, if possible you should
leave this process running, unless it is causing problems for your system.
runservice.exe is an application that does NOT appear to be a security risk
The Spy Bot database currently registers runservice.exe to eLicense.
This is part of eLicense licensing system.
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:BFtMd.16$Bs5.14@lakeread07,
+++Bobby "O"+++ <rmo555@cox.net> hunted and pecked:
> any other help? Thanks......
>> george
>>> problem and needs to close. Can anyone help? I'm using XP Pro.
Reply to Anonymous
There are 1047 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
