Power supply 560 Ti SLI
irfan88
Hello,
I have the below specifications:
Phenom II X4 955 overclocked to 4 Ghz (1.425 volts)
ASUS M4N75TD SLI AM3 Mob
Corsair 8GB DDR3 1600Mhz RAM
1 500 GB SATA II
1 1TB SATA II HDD
Kingston V64 64GB SSD
Asus GTX 560 Ti DCII
1 CD/DVD Combo
6 LED 120mm fans
4 High performance fans (Scythe, CM, Corsair)
Currently I have the 1 GTX 560Ti (900Mhz) and I would like to add another 560 Ti for SLI. I also have the Cooler master GX 750 Watt PSU which is not so efficient and many people have suggested me to change that PSU if I want to SLI with overclocking the cards upto 900 or 950 Mhz.
Please suggest me a decent power supply from Corsair, Seasonic or Cooler Master so that I can run SLI (overclocked).
Thank you.
1 500 GB SATA II
1 1TB SATA II HDD
1 CD/DVD Combo
6 LED 120mm fans
Thank you.
15
answers
Last reply
More about power supply
First off you should get one from the following list of certified SLI PSU's.
http://www.geforce.com/Active/en_US/en_US/pdf/PSU.pdf
Also make sure to get one that has 4 PCI express connectors. Corsair are on sale at newegg right now.
CORSAIR Enthusiast Series TX850 V2
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022 -
It didn't get such a great review, the one you have: http://www.hardwaresecrets.com/article/Cooler-Master-GX-750-W-Power-Supply-Review/917/10 although I have seen Coolermaster get a good review here and there. You may want to read up on a few here: http://www.hardocp.com/reviews/psu_power_supplies/
I planned on picking up one of these to run 560ti in SLI in the next few weeks. Just waiting for 560TIs to drop a few more bucks.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Power+Supplies-_-Corsair-_-17139030 -
catatafish said:It didn't get such a great review, the one you have: http://www.hardwaresecrets.com/article/Cooler-Master-GX-750-W-Power-Supply-Review/917/10 although I have seen Coolermaster get a good review here and there. You may want to read up on a few here: http://www.hardocp.com/reviews/psu_power_supplies/
How about Corsair TX 750 v2 or Corsair GS800. Will they be able to handly my Phenom at 4ghz and overclocked GTX 560 Ti's in SLI. -
The GS800 is actually what the Corsair website told me to get.
I guess I fall somewhere between the manufacturer recommendations (too conservative) and mousemonkey. That's why I landed on the one I linked, which is similar to the v2 you listed but I want the "M" for modular wiring. I think you'll probably be fine with any of them mentioned. Just depends on your budget and how many goodies you have loading it up, and where you want to fall on the PSU effeciency curve. -
irfan88 said:How about Corsair TX 750 v2 or Corsair GS800. Will they be able to handly my Phenom at 4ghz and overclocked GTX 560 Ti's in SLI.
Either of those will be more than enough but why don't you get the card first and see if the current PSU can run both of them before running out and buying a PSU that you may not need. -
Mousemonkey said:Either of those will be more than enough but why don't you get the card first and see if the current PSU can run both of them before running out and buying a PSU that you may not need.
I have already promised another guy that I would be selling the current PSU (cooler master) to him. So I want to buy another one. Which of these two would be better in terms of performance for the overclocked 560 Ti's. -
irfan88 said:I have already promised another guy that I would be selling the current PSU (cooler master) to him. So I want to buy another one. Which of these two would be better in terms of performance for the overclocked 560 Ti's.
Either would be fine I reckon, I'm using a HX620w myself. -
Sunius said:I think 900 MHz should be managable without any voltage bump or as little as 20 mV. For 950 MHz, I had to bump it to 1062 mV for it to stabilize.
BUT remember each card is different! You may not need to bump the voltage at all.
ok, but I have noticed that the ASUS GTX 560 Ti TOP 900 mhz card comes with stock 1.025 as voltage but the 830mhz variant comes with even less voltage. So I tried to bump it up to 900mhz on stock voltage but it crashed when playing crysis for 10 min.
Can u tell me a list of benchmarks that would be required to test the stability of a graphics card.
Related Resources
Graphics Cards
Power Supplies
SLI
Corsair
Graphics
Product
Related Resources
- Power supply
- Gts 450 with a cooler master power supply 460 watts
- ASUS GTX 460 768 MB on a Corsair CX500 500W Power Supply?
- Best 1000W Power Supply at a good price? Ken Tek, Corsair or OCZ
- Which power supply should I get
- Power supply for 470 gtx
- Power supply HELP!!
- What power supply do I need?
- Corsair vs Cooler Master - Also, case question.
- 450w power supply enough?
- Question about power supply and graphics cards
- Choosing Power Supply, bit of a novice.
- Cooler master silent pro or corsair hx
- Which power supply is better?
- Cool Master Power Supply
