New system wont start
Hi all. I just built my new system in the cm 690 II advanced, but the system wont start. The green light turns on but nothing happens, not even the beeping sound. Following is the pic : http://i48.tinypic.com/6hjmo2.jpg.
Please let me know if there is anything wrong with the connections and please tell me i didn't harm any component by connecting something incorrectly :(
Thanks
2 answers Last reply
More about system wont start
  1. Try putting the Memory Dimm in the first Ram slot, then if that doesn't work unplug the 24 pin and 8 pin Cables and replug them in, also make sure your Power Supply is on
  2. Done. Doesn't work. I mean why isn't it even starting :( I am too much concerned now :s
Cooler Master Light Green Components
