Is a Sound Card Worth it for me?
Hi, basically i own a Creative Fatal1ty HS-800 and i was wondering if a sound card would be worth it for me. I've had various people tell me that i won't notice a difference unless i have really expensive headphones which i can understand but feel as if it would still make some difference.
I'm not sure if this helps but my mobo is a MSI Z68A-GD55 ( with realtek and some THX tru studio pro controller
http://uk.msi.com/product/mb/Z68A-GD55--G3-.html#/?div=Overview
The sound card i had my eye on was the http://www.scan.co.uk/products/asus-xonar-dg-51-pci-sound-card-and-headphone-ampifier-oem
Asus Xonar DG 5.1 PCI Sound Card & Headphone Ampifier, OEM for £20
Will i notice a difference from onboard ?
Thanks
1 answer Last reply
More about sound card worth
  1. More than likely yes. As long as your headphones are not so crap (ex. gaming headphones or crappy headphones that cost less than $70), you will notice a small difference.
Sound Cards Creative Components
