Build new PC in the next few weeks or wait for the next gen of process
Which do you think would be best
9 answers Last reply
More about build weeks wait process
  1. MacHooper said:
    Build new PC in the next few weeks or wait for the next gen of process.
    To give reasonable advice, we need more information.
    What is your current computer configuration?
    If you currently have a 5 year old computer with something like a Core 2 Duo
    E6600. my advice would be to go ahead and build a reasonably capable new computer that will last you 3 to 5 years. On the other hand, if you already have a i7-2500K and two 570 in SLI or two 6970 in Crossfire, I would wait for the next generation.
  2. ^+1 Need to know your current config and also budget.
    Right now I just have a dell vostro 1015 laptop which has an intel celeron and is my only PC with internet, I also have a desktop with an AMD Athlon x2 but this does not have internet and I would rather build a better PC than just get internet for that one
  4. I'd say go for a Sandy Bridge chip, and if it's mainly for internet surfing, the 2500k would be more than enough.
  5. I'd say build a new Ivy bridge build now then.
  6. It will mainly be used for gaming
  7. Ivy Bridge, and a KEPLER thats what i just one week ago did, both are fresh new architectures as soon as i build it (tomorrow) will post my super power efficient computer
  8. recon-uk said:
    Nothing can beat the i5 2500k as a gaming CPU.
    An i5-3570k can beat an i5-2500k clocked 200-300MHz faster... so which one is better depends on luck with overclocking either.
    I would pick the 3570k since I have no need for uberclocking but certainly welcome 18W lower TDP, probably more at 4.0-4.2GHz.
  9. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
Build Next Generation Systems
