Are these computer parts compatible?
Hello. I've watched a lot of videos on youtube about building a new computer and I'm pretty sure I've picked out my parts correctly but I'm still hesitant before a purchase and want some help.
I bought this motherboard awhile ago when it was on sale and I wanna know if I've picked the right Processor and Ram.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
here is the processor
http://www.amazon.com/AMD-Phenom-Black-3-4Ghz-4000MHZ/dp/product-description/B002SRQ214/ref=dp_proddesc_0?ie=UTF8&n=172282&s=electronics
Here is the Ram I have already.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104173
Are these compatible and if not could someone direct me to the right part and why it is compatible? I got nervous looking at reviews on newegg and a lot of people mentioned that they have an issue with an ivy bridge.
Thanks for the help.
6 answers Last reply
More about computer parts compatible
  1. Nope, it's not going to work. You cannot put an AMD CPU into a motherboard built for intel CPUs. You can get a CPU like the i3-2100 to go with that board for the same price as the AMD CPU and it will actually be compatible.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
  2. Thank you. I'm trying to build a gaming computer on the REAL cheap. Should I wait and get a quad core or will the processor you recommended be fine?
  3. Define "REAL cheap"? What graphics are you planning to get to go with it because a gaming computer with low end graphics is a bit disappointing.
  4. NVIDIA GeForce 9500 GT. I have it in my current computer, to save money I'm going to use it until i can afford another.
  5. bump
  6. well i guess you really have to decide on which is more important to you the board or the cpu.
    if its the cpu try this motherboard : http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
    if its the motherboard then try an intel i3 processor like : http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
    but that's just my opinion (not too much experience in area)
Homebuilt Computer Compatibility Systems Product
