Hi Folks!
I am going to be building a Home Theater PC to perform the basic media functions in my home. I have been doing a fair amount of research on this but I am still a bit fuzzy on some aspects. Let me start off with some broad brush strokes.
1. Replace my dedicated Blu-Ray Player
2. DVR capabilities (dual tuner at minimum).
3. Form factor not a huge issue.
4. Budget around $500
5. IR controller capability
I am not beholden to Intel or AMD. I want as quiet a box as possible while staying as close to the budget figure as possible. I will be running Windows 7 on it. I need the IR controller capability because I want to use my Slingbox in conjunction with the HTPC.
We have most of our movies on DVD and Blu Ray. My biggest worry is smooth playback of both. We will have a large portion of our collected music on here so I am thinking at least a 750GB if not 1TB. I was looking at a Hybrid Drive from Seagate (Seagate Momentus XT 750 GB 7200RPM SATA 6Gb/s 32 MB Cache 2.5 Inch Solid State Hybrid Drive ST750LX003)
I would love some direction and advice. Issues like having a separate Graphics Card or just going with an Intel Sandybridge or likewise from AMD still need to be worked out, things like the actual Blu-Ray hardware and what is good, better, best etc.
Thanks for the input and I look forward to hearing from y'all!
