Solved
INNO3D 9500GT issue..PLEASE HELP!!
Hello to all the community members here in Tom's.
I have an issue with my INNO3D 9500GT 1GB 128bit video card. Whenever I plug it in my computer and use it, Windows cannot continue to load up to the desktop display. After the Windows loading screen, it can't proceed to the log-on screen. A blue screen appears for a couple of seconds saying that a new hardware causes the problem then the PC restarts.
I'm still a newbie on this field but I am willing to learn how to troubleshoot such problems.
It would be very much appreciated if someone knowledgeable around here could help me out with my dilemma. Thanks!
15 answers Last reply Best Answer
More about inno3d 9500gt issue please help
  1. PC have enough power to run it? Have all the power plugs in?
    Try the card in another PC to rule out a bad card.
  2. yes i believe my PC has enough power to run with. i'm still yet tot try it on another pc..
  3. If it's a bad card, Is there any way it could still be repaired?
  4. You are asking questions and expecting answers without providing any info. You need to list full system specs, including what power supply you have in order for anyone to even have a chance at helping you out with your problem.
  5. repair is not likely unless you can see the part that is broken.. Try in another computer then you will Know if its junk or not.
    Thent
  6. Alright here is the full system specs of my PC:
    MOBO: Biostar MCP6PB M2+
    PROC: AMD Athlon X2 5000+
    GPU: INNO3D 9500GT 1gb 128bit
    RAM: 1 x 2gb
    HDD: 80GB
    PSU: 500watts generic power supply
    OPTICAL DRIVE: 1 DVD-ROM
    OS: windows 7 SP1
    others:
    2 x 80mm cpu fans
    1 LAN card
    Is it possible that my PSU is unable to supply enough power to the GPU?
  7. does it boot in safe mode?
    could be a driver issue.
  8. A cheap PSU would have issues yes. Which is why I asked about power to run it. Either try with a better power supply, or try in another PC with a good power supply.
  9. @cale_afterearth: YES it can boot in safe mode and it recognizes the vcard when I check it in Device Manager.
    @hang-the-9: I am still to try a better power supply with the system, and try it on another PC as well. maybe I could post the result later. I still have to sleep. =)
  10. Hey guys I've tried to change the PSU with a better one and I also tried to use the video card on another computer with a better PSU but still the problem occured, blue screen appears after windows 7 loading screen.
    I think the problem here is with the GPU itself. Isn't it?
    Does seem that way. Good chance to swap out for a much better card :-)
  12. But it runs well on safe mode, could it be a driver problem?
    I still don't want to give up on this since I don't have a budget to get a new card yet. hehe
  13. Best answer
    Safe mode does not use any features of the card, and you tried it with another PC, that should rule out any operating system or driver issues. I have seen many dead cards that work fine in Safe Mode, but crash soon as anything more advanced is used.
    Any video card should be able to boot up the PC normally and allow you the chance to install the drivers from the vendor at least.
  14. Best answer selected by shoyee.
  15. Thanks mates for all the time and effort to helping me. I really need to change my card then.
Nvidia Graphics
