Can someone confirm it? I am worried that she might blow the component's of the computer I gave her
it's a Cooler Master Extreme Power Plus 500 watt
http://www.coolermaster.com/product.php?product_id=3738 , My Cousin bought the gpu without knowing if the power supply will run it .
well, the power supply powered the 9800 GT 512mb OC edition from gigabyte ...
and + I am guessing the GTX 550 ti will run just fine on idle & Full load, Another I remember I created a thread that someone said that a 560gtx will run on that particular PSU without any problem's ,
this is her gtx 550 ti http://www.newegg.com/Product/Product.aspx?Item=N82E16814121435
note: I am aware that the PSU isn't the best nor good...
thank you in advance
